Skip to main content
Skip table of contents
Analysis + Design (F9)
Analysis+Design performs the vertical load and modal analysis of the structure and the concrete and steel element design, including the foundation and slab analysis, depending on the Analysis Settings parameters. Horizontal and vertical load analysis is performed automatically, and the design results of concrete and steel elements are calculated automatically by automatically creating loading combinations.
Click the Analysis + Design icon in the ribbon menu for the operation, press the F9 key on the keyboard.
Do you want to perform analysis option will open.
When the OK button is clicked, the analysis + design process will start.
In the analysis status window, the steps and process times applied during the analysis + design process are given for information purposes.
Slab Analysis
JavaScript errors detected
