Skip to main content
Skip table of contents
3D Isometric View Drawings
The 3D Isometric View Drawings command is used to prepare 3D isometric view drawings.
Location of the 3D Isometric View Drawings Command
  • Click the 3D Isometric View Drawings icon.
  • Isometric view drawing will be created.
  • Before creating the drawings, you can access the Steel Drawing Settings dialog by clicking the settings button from the steel drawings dialog . From this dialog, layout settings, scales, fonts, etc. You can access parameters related to steel drawings.
Sample 3D isometric view drawing
JavaScript errors detected
